Minitiouner Hardware
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
Original schematics are here : http://www.vivadatv.org/viewtopic.php?f=80&t=366
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on these wiki pages - to build the unit you only need to buy the following and then download the free MiniTioune software.
- The USB interface is available ready programmed from the BATC shop.
- The main version 2 PCB can be bought from the BATC shop. New builders will use the Serit tuner and version 2 PCB only.
- The tuner or NIM. The Serit unit covering 143 - 2450 MHz is available from the BATC shop
- All other components are available from normal suppliers.
Overview
The MiniTiouner hardware consists of 2 main parts which sit on a main PCB which is sold by the BATC shop.
MiniTiouner main PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
The NIM or Network interface module is the little metal box found inside Satellite Receivers (also called the tuner) and typically contains 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
Note: As of April 2017 a new main PCB is being designed to directly take the Serit tuner - any new constructors should wait for the new board which will not need the adapter PCB. You only require the adaptor PCB if you are upgrading existing MiniTiouner hardware to include the Serit tuner. Check this page to work out if you should upgrade.
Compatible NIM types
- Zero tuner chip can be STB6100, STV6110, STV6111, STV6120
- Demodulator chip STV0903, STV0913, STV0910
- Eardatek EDS-4B47FF1B+ (sold by BATC shop during 2015 / 16)
- Sharp F7VZ0169 (sold by BATC shop during 2016)
- Samsung DNBU10711IST
- Samsung DNBU10512IST
- LG TDQX-S001F
- Serit SP2246
- Serit FTS-4335 (Sold by BATC shop in 2017)
Fitting a lock detector
