Revision as of 19:59, 30 April 2017 by G8GTZ (talk | contribs) (Created page with "The Minitiouner hardware is designed for home construction and consists of the 3 main components described on these wiki pages - to build the unit you only need to buy the fol...")
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on these wiki pages - to build the unit you only need to buy the following and then download the free MiniTioune software.
  • The main version 2 PCB can be bought from the BATC shop. New builders will use the Serit tuner and version 2 PCB only.
  • All other components are available from normal suppliers.
MiniTiouner main PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
