Serit tuner
Revision as of 20:09, 30 April 2017 by G8GTZ (talk | contribs)
  • If neither of those apply, you don't need one!
Serit adapter card
The Serit tuner has a different pin out to the original Sharp unit and as of April 2017 a version 2 main PCB has been designed to directly take the Serit tuner - any new constructors should use this version 2 new board which will not need the adapter PCB.
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Dual receiver
NIM pinouts
Serit datasheets
File:FTS-4335 Series_F2.pdf
File:FTS-4334L Series_F1.pdf
