Minitiouner Hardware
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page - New builders will use the Serit tuner and version 2 PCB only.
  • The version 2 main PCB can be bought from the BATC shop.
All other components such as Rs and Cs are available from normal suppliers, however the unit uses a hard to get 1v regulator, which is available from the BATC shop. A BoM for the version 2 PCB is available on the V2 wiki page and can be used to order all parts from Digikey.
MiniTiouner main PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
inside a NIM
Compatible NIM types
  • Samsung DNBU10711IST
  • Samsung DNBU10512IST
  • LG TDQX-S001F
  • Serit SP2246
  • Serit FTS-4335 (Sold by BATC shop in 2017)
Fitting a lock detector
