Serit tuner
- You should buy one if you already have MiniTiouner hardware and you want to be able to receive 146 MHz and 70cms without building an upconverter.
- You should buy one if you already have MiniTiouner hardware and want to experiment with the higher DVB-S2 modes such as 32APSK which the Sharp NIM cannot demodulate.
- You should buy one if you have not yet built a MiniTiouner receiver as the previous Sharp tuner is no longer available.
- If neither of those apply, you don't need one!
The Serit tuner has a different pin out to the original Sharp unit and as of April 2017 a version 2 main PCB has been designed to directly take the Serit tuner - any new constructors should use this version 2 new board.
Serit adapter card
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Dual receiver
NIM pinouts
Serit datasheets
