Serit tuner
Revision as of 06:40, 1 May 2017 by G8GTZ (talk | contribs)
  • If neither of those apply, you don't need one!
2 versions of the Serit NIM!
Just to confuse the issue further, there are 2 versions of the Serit NIM!
The only difference between the FTS-4335, which was sold in the BATC shop before before April 2017, and the FTS-4334 sold after May 2017 is the addition of an amplifier stage before the tuner.
====Serit FTS-4335 (sold before April 2017)
To overcome the lack of a pre-amp an additional satellite line amp from ebay maybe used in front of the tuner.
====Serit FTS4334 (sold after May 2017)
Serit adapter card
Filters and pre-amps
Dual receiver
NIM pinouts
Serit datasheets
File:FTS-4335 Series_F2.pdf
File:FTS-4334L Series_F1.pdf
