Serit tuner
If none of the above apply, you don't need one!
2 versions of the Serit NIM!
Just to confuse the issue further, there are now 2 versions of the Serit NIM!  Both types work with the new Version 2 MiniTiouner PCB and adapter card for the Version 1 PCB.
The only difference between the FTS-4335, which was sold in the BATC shop before before April 2017, and the FTS-4334 sold after May 2017 is the addition of an amplifier or booster stage before the tuner.
The units can be identified by the model number, which is printed on the opposite end of the unit to the F type connectors.
Serit FTS-4335 (sold before April 2017)
To overcome the lack of a pre-amp an additional satellite line amp from ebay maybe used in front of the tuner.
Serit FTS4334 (sold after May 2017)
Picture to follow as soon as the units arrive from China.
The FTS-4334 unit has a built in booster and will not require an external line amplifier.
Serit adapter card
Filters and pre-amps
Dual receiver
NIM pinouts
Serit datasheets
File:FTS-4335 Series_F2.pdf
File:FTS-4334L Series_F1.pdf
