Minitiouner Hardware
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
New builders will use the Serit tuner and version 2 PCB only.
  • The version 2 main PCB can be bought from the BATC shop.
  • The tuner or NIM. The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
All other components such as Rs and Cs are available from normal suppliers. A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts from Digikey.
MiniTiouner main PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
inside a NIM
However, due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM tuner will also need a simple adapter board to enable it to be plugged in to the Version 1 MiniTiouner hardware - Brian G4EWJ has designed a board and these are available from the BATC shop. The adapter board and the Serit FTS4335 NIM tuner are available from the BATC shop.
Fitting a lock detector
