Minitiouner Hardware
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
New builders will use the Serit tuner and version 2 PCB only.
  • The version 2 main PCB can be bought from the BATC shop.
  • The tuner or NIM. The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
All other components such as Rs and Cs are available from normal suppliers. A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts directly from Digikey.
MiniTiouner main PCB
There are 2 variants of the MiniTiouner main PCB which contains the power supply components for the 5, 3.3 and 1 volt rails. As of April 2017 new builders should only build version 2.
See this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
inside a NIM
However, due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM tuner will also need a simple adapter board to enable it to be plugged in to the Version 1 MiniTiouner hardware - Brian G4EWJ has designed a board and these are available from the BATC shop. The adapter board and the Serit FTS4335 NIM tuner are available from the BATC shop.
Fitting a lock detector
