The Minitiouner hardware is designed for home construction and consists of the 3 main components described on these wiki pages - to build the unit you only need to buy the following and then download the free MiniTioune software.
- The USB interface is available ready programmed from the BATC shop.
- The main version 2 PCB can be bought from the BATC shop. New builders will use the Serit tuner and version 2 PCB only.
- The tuner or NIM. The Serit unit covering 143 - 2450 MHz is available from the BATC shop
- All other components are available from normal suppliers.
MiniTiouner Version 2 PCB
More details to follow but the schematic can be downloaded:
