Revision as of 07:32, 1 May 2017 by G8GTZ (talk | contribs)
Whilst the project had previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the Serit tuner and version 2 PCB described on this page.
  • The version 2 main PCB can be bought from the BATC shop.
  • The tuner or NIM. The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
All other components such as Rs and Cs are available from normal suppliers.
MiniTiouner Version 2 PCB
More details to follow but the schematic can be downloaded:
File:SERIF.pdf
