Revision as of 08:26, 1 May 2017 by G8GTZ (talk | contribs) (→Building the Version 2 MiniTiouner PCB)
Whilst the project had previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the Serit tuner and version 2 PCB described on this page.
- The USB interface is available ready programmed from the MiniTiouner category in the BATC shop.
- The version 2 main PCB can be bought from the BATC shop after May 5th 2017.
- The Serit tuner or NIM covering 143 - 2450 MHz will be available from the BATC shop from early May 2017.
- The unit uses an MCP1826 1v regulator, which can be hard to find and is available from the BATC shop.
All other components such as Rs and Cs are available from normal suppliers.
More details to follow but the parts list and schematic can be downloaded:
