Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page and the Serit tuner described here.
  • The version 2 main PCB can be bought from the BATC shop after May 5th 2017.
  • The Serit tuner or NIM covering 143 - 2450 MHz will be available from the BATC shop from early May 2017.
The PCB has been developed to fit snuggly inside a Hammond 1455 series 103x160x53mm enclosure - note both pictures show the beta board and the final board will be shorter and may fit inside the 120mm long box.
Parts list and schematic
More details to follow but the parts list and schematic can be downloaded:
File:SERIF.pdf
File:Seritparts.pdf
On the air
The version 2 PCB with Serit tuner is the only available solution to receive and decode DVB-S2 reduced bandwidth modes (the version 1 PCB with adaptor card did as well) - this picture shows G0MJW receiving G8GTZ/p on 146 MHz using 16 APSK (approximately 1 mbit/s in 550 KHz bandwidth).
