Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use this version 2 PCB described on this page and the Serit tuner described here.
If you already have version 1 MiniTiouner, then you probably don't need one unless you want a smaller board. (NOTE:The version 2 PCB ONLY takes the Serit tuner and you may be better off with the Serit adapter board).
- The USB interface is available ready programmed from the MiniTiouner category in the BATC shop.
- The version 2 main PCB can be bought from the BATC shop after May 5th 2017.
- The Serit tuner or NIM covering 143 - 2450 MHz will be available from the BATC shop from early May 2017.
- The unit uses an MCP1826 1v regulator, which can be hard to find and is available from the BATC shop.
The PCB has been developed to fit snuggly inside a Hammond 1455 series 103x120x53mm enclosure.
Parts list and schematic
More details to follow but the parts list and schematic can be downloaded:
The blank PCB will be available from the BATC shop in early May
On the air
