MiniTioune
Revision as of 10:00, 9 May 2017 by G8GTZ (talk | contribs)
The MiniTioune receiver project, developed by Jean-Pierre F6DZP, consists of the home constructed MiniTiouner hardware which interfaces via a standard USB 2.0 port to a Windows PC running the MiniTioune software.
Serit complete.jpg Hardware <------------> Windows Software G8GTZ 32 APSK Portsdown.jpg
It will receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second.
It can be used to receive satellite broadcasts, "normal" DATV signals and is the ONLY system capable of receiving Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
Hardware overview
Full details of the MiniTiouner hardware and build information are available here.
Full details of the MiniTioune software designed to be used with the MiniTiouner hardware are available here MiniTioune software.
Band Pass filters
Receive upconverters
The original Sharp and Eardatek tuner components (also called NIM) used in MiniTiouner cover a maximum of 650 to 2600 MHz.
