MiniTioune software
Revision as of 06:07, 12 May 2017 by G8GTZ (talk | contribs)
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need a log-in to download the software.
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner. The files is located here: Minitioune v0.6d download
Download the zip file and extract to a folder under your root or c:\ directory. You should have the following files in your directory:
Software Installation
