MiniTioune software
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software.
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner. The files is located here: Minitioune v0.6d download
Download the zip file and extract to a folder under your root or c:\ directory. You should have the following files in your directory:
The following files are in the directory:
* "readme.pdf" - gives the latest information and a step by step guide to using MiniTioune software version 6d
* "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - A program to run at first installation to check you have installed all the drivers and filters needed to run MiniTioune
* "install_usrc_ax_winXP.exe" - you will need to run this for all versions of Windows (not just XP) to install the usrc filters
Software Installation
Onc you have unzipped the main download you need to follow 4 easy steps to get up and running:
  • Run the MiniTiouner tesst program - it should pass on all sections.
  • You are now ready to run the main MiniTiouner_v0.6d program.
