MiniTioune software
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software. The files is located here: Minitioune v0.6d download
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner.
Download the zip file and extract to a folder under your root or c:\ directory. You should have the following files in your directory:
The following files are in the directory:
* "readme.pdf" - gives the latest information and a step by step guide to using MiniTioune software version 6d
* "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - A program to run at first installation to check you have installed all the drivers and filters needed to run MiniTioune
* "install_usrc_ax_winXP.exe" - you will need to run this for all versions of Windows (not just XP) to install the usrc filters
Software Installation
  • Run the MiniTiouner tesst program - it should pass on all sections.
  • You are now ready to run the main MiniTiouner_v0.6d program.
For a very comprehensive guide on this see the paper written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
The Minitioune software is very comprehensive DVB-S receive and diagnostic software but can be a little baffling when first running it!
If you have completed the installation and tested your system by running the test program, you now need to arrange a test signal and you will need to know the following:
  • Signal frequency (this should the L band signal frequency coming out of the LNB)
  • Modulation mode - DVB-S or DVB-S2
  • The Symbol Rate or SR - this will probably be listed as MegaSymbols - eg 2Ms or 27Ms - you will need to convert this to Ks - eg 2000 or 27000
  • A satellite signal from your domestic sattelite dish
