MiniTioune software
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software. The files is located here: Minitioune v0.6d download
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner.
Download the zip file and extract to a folder under your root or c:\ directory. You should have the following files in your directory:
The following files are in the directory: * "readme.pdf" - gives the latest information and a step by step guide to using MiniTioune software version 6d * "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - A program to run at first installation to check you have installed all the drivers and filters needed to run MiniTioune * "install_usrc_ax_winXP.exe" - you will need to run this for all versions of Windows (not just XP) to install the usrc filters
Software Installation
- Download and install the D2XX drivers 2.12.24 found at http://ftdichip.com/Drivers/D2XX.htm. There's a link in the right column for a setup executable.
- Download and install LAVfilters CODECs from here http://www.videohelp.com/software/LAV-Filters
- Plug in your MiniTiouner hardware and let the USB drivers install.
- Run the MiniTiouner tesst program - it should pass on all sections.
- You are now ready to run the main MiniTiouner_v0.6d program.
For a very comprehensive guide on this see the paper written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
The Minitioune software is very comprehensive DVB-S receive and diagnostic software but can be a little baffling when first running it!
- A satellite signal from your domestic sattelite dish.
- A local DATV signal from Portsdown (Ugly mode is fine) or any other DATV transmitter.
- An off air DATV signal from your local repeater or "buddy down the road" (did I really write that!)
- Signal frequency - this should the L band signal frequency coming out of the LNB or direct amatuer band frequency - eg 1255MHz or 1563 MHz
- Modulation mode - DVB-S or DVB-S2
- The Symbol Rate or SR - this will probably be listed as MegaSymbols - eg 2Ms or 27Ms - you will need to convert this to Ks - eg 2000 or 27000
- The FEC rate - this will be written in the form 1/2 or 5/6
