MiniTioune software
Revision as of 07:06, 12 May 2017 by G8GTZ (talk | contribs)
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software. The files is located here: Minitioune v0.6d download
The latest (28 February 2017) version of MiniTioune is V0.6d and is the version you will need if you have a Serit tuner.
Software Installation
  • Run the MiniTiouner tesst program - "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - it should pass on all sections.
  • You are now ready to run the main MiniTiouner_v0.6d program.
For a very comprehensive guide on this see the paper written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
The Minitioune software is very comprehensive DVB-S receive and diagnostic software but can be a little baffling when first running it!
  • A satellite signal from your domestic sattelite dish.
  • A local DATV signal from Portsdown (Ugly mode is fine) or any other DATV transmitter.
  • An off air DATV signal from your local repeater or "buddy down the road" (did I really write that!)
  • Signal frequency - this should the L band signal frequency coming out of the LNB or direct amatuer band frequency - eg 1255MHz or 1563 MHz
  • Modulation mode - DVB-S or DVB-S2
  • The Symbol Rate or SR - this will probably be listed as MegaSymbols - eg 2Ms or 27Ms - you will need to convert this to Ks - eg 2000 or 27000
Start the program and you should see the "Please wait 10 seconds message" and then the following screen:
Navigate your mouse to the top left corner of the screen and setting the following parameters to match your test signal:
  • Frequency
  • SR - symbol rate
  • FEC - tick the box to match the FEC you are running.
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER and the Verberti error bar graph should go green.
If this has happened but there is no video displayed in the center window, navigate to the top right of the screen and click the "auto PID" button - the video should now appear.
You can edit the miniTioune.ini file in the download directory to configure the preset buttons for commonly used parameters.
To do this, first save a copy of the file on to your desktop - this is so you can always go back when you mess up! Then double click the file and it should open in wordpad.
More to follow.....
