MiniTioune software
Software Installation
  • You are now ready to run the main MiniTiouner_v0.6d program.
  • A satellite signal from your domestic sattelite dish.
  • DVB mode - DVB-S or DVB-S2
Start the program and you should see the "Please wait 10 seconds message" and then the following screen:
  • Symbol rate (SR) - type the symbol rate directly in to the top left green box. (Note this should be the SR in kilosymbols in the following form - 02000 for 2Ms, 00250 for 250kS or 27000 for 27Ms)
  • FEC - tick the box to match the FEC you are running.
  • DVB mode - tick the corect mode box. All DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER and the Verberti error bar graph should go green.
You can edit the miniTioune.ini file in the download directory to configure the preset buttons for your commonly used parameters.
To do this, first save a copy of the file on to your desktop - this is so you can always go back when you mess up! Then double click the file and it should open in wordpad.
More to follow.....
