Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use this version 2 PCB described on this page and the Serit tuner described here.
  • The version 2 main PCB can be bought from the BATC shop after May 5th 2017.
  • The Serit tuner or NIM covering 143 - 2450 MHz will be available from the BATC shop from early May 2017.
Setting up and testing the hardware
There is not much to set up but before connecting the DC-DC converter to the input of the linear regulators, the output MUST be set to 3.7-4v output. This is because these LDO regulators can only take about 6V. There is a zener to provide some protection but damage is still possible and worst case you could end up with whatever is on the input appearing at the output - i.e. 5.6V on the 3.3V and 1.2V rails.
We recommend that you build and then test all the voltage rails BEFORE fitting the NIM. This is easy as you can probe the top of the RFCs.
Parts list and schematic
The parts list and schematic can be downloaded here:
File:SERIF.pdf
File:Seritpartsv3.xls
On the air
