Revision as of 08:27, 12 May 2017 by G8GTZ (talk | contribs)
Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use this version 2 PCB described on this page and the Serit tuner described here.
  • The version 2 main PCB can be bought from the BATC shop after May 5th 2017.
  • The Serit tuner or NIM covering 143 - 2450 MHz will be available from the BATC shop from early May 2017.
Setting up and testing the hardware
The design uses a switched DC to DC converter to reduce the 12v input to 4v and thereby reduce the amount of generated heat - this is then followed by 3 linear regulators to ensure noise free voltage rails for maximum RF performance.
We recommend that you build and then test all the voltage rails BEFORE fitting the NIM. This is easy as you can probe the top of the RFCs.
Parts list and schematic
The parts list and schematic can be downloaded here:
File:SERIF.pdf
File:Seritpartsv3.xls
On the air
