MiniTioune software
Software Installation
  • DVB mode - DVB-S or DVB-S2
Start the program and you should see the please wait message - if you get the USB error message then you hardware is not connected.
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto.
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
More to follow.....
