Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page and the Serit tuner described here.
Mike, G0MJW, has written some instructions on building and testing the board.
File:Notes on building the BATC v2 Minitiouner.pdf
Setting up the hardware
The design uses a switched DC to DC converter to reduce the 12v input to 4v and thereby reduce the amount of generated heat - this is then followed by 3 linear regulators to ensure noise free voltage rails for maximum RF performance.
We recommend that you build and then test all the voltage rails BEFORE fitting the NIM. This is easy as you can probe the top of the RFCs.
Parts list and schematic
The parts list and schematic can be downloaded here:
Note the electrolytic capacitors are High ESR types chosen to minimise oscillation from the linear regulators - substitute at your peril!
File:SERIF.pdf
File:Seritpartsv3.xls
On the air
