Revision as of 17:22, 22 May 2017 by G8GTZ (talk | contribs)
The aim of the project is to enable an amateur radio operator with little or no knowledge of Digital ATV to construct the hardware elements, load and configure the software and use the system to send live Digital ATV signals across town on his existing aerials.
• Frequency coverage of the 71, 146 MHz, 437 MHz and 23cms ATV bands (13cms available at reduced output)
Note - the Portsdown project has evolved since the original articles were written and now defines just the Raspberry Pi based transmitter - there is no Portsdown receiver project although it is possible to add an RTL dongle based monitoring receiver.  The MiniTioune USB receiver project is the recommended receive solution for all DATV transmissions including the Portsdown transmitter.
System overview
At the heart of the The Portsdown Transmitter is a Raspberry Pi (RPi) computer running a BATC customised version of the F5OEO rpidatv software. The choice of the RPi is primarily due to the fact that it has an on-board MPEG-4 (H264) encoder and the versatile hardware interface (GPIO) capabilities. 1-1 Block Diagram.jpg
Touch screen control
Modulator and Filter board
The output from the Rpi is connected to the Filter Modulator board which modulates the RF carrier and produces the DVB-S DATV signal - Blank PCBs and fully assembled boards are available from the BATC shop).
Audio and video inputs
Next steps?
Finally TXfactor have produced a great video introducing and explaining Portsdown and ATV in action - take 15 minutes to watch it here.
