MiniTioune software
Revision as of 07:14, 25 May 2017 by G8GTZ (talk | contribs)
Software Installation
  • DVB mode - DVB-S or DVB-S2
Start the program and you should see the please wait message - if you get the USB error message then you hardware is not connected.
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto.
If you are using a Serit tuner, which covers 144 - 2550 MHz without any upconverters, make sure you have no offset in the white box under the frequency box.  If there is a a number present simply enter "00000000".  If you are using a Sharp tuner with an upcoverter you will need to enter the L band frequency in the green box or the receive frequency in the green box plus LO offset in the white box.
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
More to follow.....
