MiniTioune software
Software Installation
- Download and install the D2XX drivers 2.12.24 found at http://ftdichip.com/Drivers/D2XX.htm. There's a link in the right column for a setup executable.
- Download and install LAVfilters CODECs from here http://www.videohelp.com/software/LAV-Filters
- Plug in your MiniTiouner hardware and let the USB drivers install.
- Run the MiniTiouner test program - "CheckMiniTiouneDriverAndFilters_V0_3a.exe" - it should pass on all sections.
There is a readme file contained in the download which you should read. For a very comprehensive guide on the software installation, see the paper written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
- A satellite signal from your domestic satellite dish.
- A local DATV signal from Portsdown (Ugly mode is fine) or any other DATV transmitter - a short piece of wire in the tuner input socket will probably pick up enough signal but be careful - there maybe DC volts on the socket.
- An off air DATV signal from your local repeater or "buddy down the road" (did I really write that!) - make sure you have a filter and line amplifier between your pre-amp and tuner input but be careful - there maybe DC volts on the input socket and most filters are DC short circuit.
- Signal frequency - you will need to know L band signal frequency coming out of the LNB or direct amatuer band frequency - eg 1255MHz or 1563 MHz
- DVB mode - DVB-S or DVB-S2
- The Symbol Rate or SR - this will probably be listed as MegaSymbols - eg 2Ms or 27Ms - you will need to convert this to kS - eg 2000 or 27000
- The FEC rate - this will be written in the form 1/2 or 5/6
Start the program and you should see the please wait message - if you get the USB error message then you hardware is not connected.
- Symbol rate (SR) - type the symbol rate directly in to the top left green box. (Note this should be the SR in kilosymbols in the following form - 00250 for 250kS, 02000 for 2Ms,or 27000 for 27Ms.
- Frequency - type directly in to the top right green box. (Note this should be the L band frequency in the following form - 01255000 for 1255MHz. if it is not the correct format the box will be greyed out).
- FEC - tick the box to match the FEC of the transmission you are wanting to rx.
- DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto.
If you are using a Serit tuner, which covers 144 - 2550 MHz without any upconverters, make sure you have no offset in the white box under the frequency box. If there is a a number present simply enter "00000000". If you are using a Sharp tuner with an upcoverter you will need to enter the L band frequency in the green box or the receive frequency in the green box plus LO offset in the white box.
- The preset buttons for Frequency (with LNB / converter offsets), symbol rates and PID (see below)
- FEC selected on startup
- DVB mode on start up
- DC volts on tuner output
- Your call sign and station details for the web monitoring facility (see below)
More to follow.....
