MiniTioune software
Software Installation
Connecting the hardware
It is absolutely essential you use a high quality cable or the program will frequently freeze and crash with no warning - the recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
  • DVB mode - DVB-S or DVB-S2
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2 but if you are unsure, tick auto.
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
More to follow.....
