5.6 GHz
Revision as of 18:14, 18 September 2017 by G8GTZ (talk | contribs)
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Antenna change over relays
The losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length. The surplus SMA relays often available at rallys are ideal for 5.6 GHz. If no suitable relay is available It may be cheaper to use a separate antenna for receive and transmit as shown in the picture below.
Reverse SMA
24v relay operation
Antennas
As 5.8GHz is also used by broadband wireless networks, there is a wide choice of antennae available for use on 5.6GHz ATV. This can range from flat plates to wire mesh dishes.
It is also possible to use a satellite mini dish with a suitable feed - the picture shows a Sky mini dish fed with a WA5VJB log period PCB feed (available from G4DDK).
Using dish aerials of 30 – 60 cm (such as a surplus Sky dish), line of sight ranges of 80 km can easily be achieved. P5 (noise free) FM ATV pictures have been exchanged over an 85 km path using the equipment pictured.
