5.6 GHz
Revision as of 18:22, 18 September 2017 by G8GTZ (talk | contribs) (→Antennas)
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Antenna change over relays
The losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length. The surplus SMA relays often available at rallys are ideal for 5.6 GHz.
Reverse SMA
24v relay operation
Antennas
On the air
