5.6 GHz
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
You will also need a video input monitor - beware of the blue screen on noise effect - and an old camcorder with a yellow phono video out socket.
Antenna change over relays
The losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length. The surplus SMA relays often available at rallys are ideal for 5.6 GHz.
Reverse SMA
24v relay operation
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
