5.6 GHz
Revision as of 19:15, 18 September 2017 by G8GTZ (talk | contribs) (→Video equipment)
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
Rx
Tx
Antenna change over relays
The losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length. The surplus SMA relays often available at rallys are ideal for 5.6 GHz.
Reverse SMA
24v relay operation
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
