5.6 GHz
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
Rx
Tx
Antenna change over relays
The FPV equipment comes as separate Tx and Rx units. In order to operate on a single aerial, you will need an antennae changeover relay, however the losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length. PL259 and even BNC connectors are very lossy at 5.6GHz but the surplus SMA relays often available at rallys are ideal for 5.6 GHz.
Reverse SMA
24v relay operation
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
