5.6 GHz
Revision as of 19:20, 18 September 2017 by G8GTZ (talk | contribs) (→Reverse SMA)
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
Rx
Tx
Antenna change over relays
The FPV equipment comes as separate Tx and Rx units. In order to operate on a single aerial, you will need an antennae changeover relay, however the losses at 5.6GHz can be significant and care must be taken when wiring up the units to ensure RF cables are of good quality and kept to a minimum length.
PL259 and even BNC connectors are very lossy at 5.6GHz but the surplus SMA relays often available at rallys are ideal for 5.6 GHz.
Reverse SMA
Be aware that all the 5.6GHz FPV units are reverse SMA (like wifi equipment) and all low loss cables (semi rigid is ideal) and suplus SMA relays are almost certain to be standard SMA connectors and will not fit. Adapters from reverse to standard SMA are available on ebay or other suppliers.
24v relay operation
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
