5.6 GHz
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
Rx
Tx
Antenna change over relays
Reverse SMA
24v relay operation
Most of these relays are often 24v coils - use a switching regulator from ebay as shown in the picture (search for step up buck regulator) to boost the 12volts on transmit to 24v.
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
