5.6 GHz
Revision as of 19:35, 18 September 2017 by G8GTZ (talk | contribs) (→Introduction)
It has just become very easy (and low cost) to get on the air on 5.6GHz or the 6 cm amateur band due to the availability of cheap modules intended to transmit “First Person Video” (FPV) back from drones to their operators.
Frequency choice
Equipment
G8GKQ 6cm Transceiver - .
Video equipment
Rx
Tx
Antenna change over relays
Reverse SMA
24v relay operation
Most of these relays are often 24v coils - use a switching regulator from ebay as shown in the picture (search for step up buck regulator) to boost the 12volts on transmit to 24v.
Antennas
On the air
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
More information
