5.6 GHz
It has just become very easy (and low cost) to get on the air on 5.6GHz (the 6 cm amateur band) using the cheap modules intended to transmit “First Person Video” (FPV) back from drones to their operators.
Frequency choice
Equipment
Mounting the equipment
Due to the very high losses in co-ax cable at 5.6GHz it is recommended that you mount the units very close to the antennae and run 12v DC and Audio and video back down the cable to the shack or operating position. Also whilst these units are very small but do run very hot in operation and it is suggested you provide a good heatsink for both Tx and Rx - mounting them in a diecast box on the back of the antennae is ideal.
Video equipment
Rx
Tx
Antenna change over relays
Reverse SMA
24v relay operation
Most of these relays are often 24v coils - use a switching regulator from ebay as shown in the picture (search for step up buck regulator) to boost the 12volts on transmit to 24v.
Antennas
On the air
Activity hot spots
Know users include:
- Hereford = G8XYJ
- Yorkshire = G8BYN
- Norfolk = G4NJJ, G8AJN and M1BKF
More information
