5.6 GHz
Revision as of 19:49, 18 September 2017 by G8GTZ (talk | contribs)
It has just become very easy (and low cost) to get on the air on 5.6GHz (the 6 cm amateur band) using the cheap modules intended to transmit “First Person Video” (FPV) back from drones to their operators.
Frequency choice
Equipment
Mounting the equipment
Due to the very high losses in co-ax cable at 5.6GHz it is recommended that you mount the units very close to the antennae and run 12v DC and Audio and video back down the cable to the shack or operating position. Also whilst these units are very small but do run very hot in operation and it is suggested you provide a good heatsink for both Tx and Rx - mounting them in a diecast box on the back of the antennae is ideal.
G8GKQ 6cm Transceiver - .
Transmit amplifiers
Antenna change over relays
Reverse SMA
24v relay operation
Antennas
Video equipment
Rx
Tx
On the air
Using dish aerials of 30 – 60 cm line of sight ranges of 80 km can easily be achieved.
P5 (noise free) FM ATV pictures have been exchanged over an 138km path using the equipment pictured - the picture below shows G4COE being received over a slightly obstructed 66Km path.
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
More information
