5.6 GHz
It has just become very easy (and low cost) to get on the air on 5.6GHz (the 6 cm amateur band) using the cheap modules intended to transmit “First Person Video” (FPV) back from drones to their operators.
Frequency choice
Equipment
Mounting the equipment
Transmit amplifiers
Antenna change over relays
Reverse SMA
24v relay operation
Antennas
Video equipment
Rx
Tx
On the air
Using dish aerials of 30 – 60 cm line of sight ranges of 80 km can easily be achieved.
P5 (noise free) FM ATV pictures have been exchanged over an 138km path using the equipment described on this page - the picture below shows G4CPE/p being received over a slightly obstructed 66Km path.
Activity hot spots
Know users include:
- Hereford = G8XYJ
- Yorkshire = G8BYN
- Norfolk = G4NJJ, G8AJN and M1BKF
More information
