5.6 GHz
Revision as of 20:19, 18 September 2017 by G8GTZ (talk | contribs) (→‎Equipment)
Frequency choice
Equipment
Mounting the equipment
G8GKQ 6cm Transceiver - .
Transmit amplifiers
Antenna change over relays
Reverse SMA
24v relay operation
Antennas
Video equipment
Rx
Tx
On the air
P5 (noise free) FM ATV pictures have been exchanged over an 138km path using the equipment described on this page - the picture below shows G4CPE/p being received over a slightly obstructed 66Km path.
Activity hot spots
Know users include:
  • Hereford = G8XYJ
  • Yorkshire = G8BYN
More information
