5.6 GHz
Frequency choice
Equipment
Mounting the equipment
Transmit amplifiers
Antenna change over relays
Reverse SMA
24v relay operation
Antennas
Video equipment
Rx
Tx
On the air
Activity hot spots
Know users include:
- Hereford = G8XYJ
- Yorkshire = G8BYN
More information
Technical information
The rx chip in most units has got the number removed, however the module the rxr is based is called an SM201R - the spec and pinout are shown below:
S meter output
It appears the unit using a 480MHz IF (same as the Comtech) and more interesting the RSSI is available on pin 17 and could potentially be used for a signal strength meter to help align the antennae.
