PTT and band switching
Band outputs
| Frequency Mhz | ATV Band | Pin 28 | Pin 35 |
| < 100 MHz | 71 MHz | Lo | Lo |
| 100 - 250 MHz | 146 MHz | Lo | Hi |
| 250 - 950 MHz | 437 MHz | Hi | Lo |
| 950 - 4400 MHz | 23cms | Hi | Hi |
GPIO band decoder
PTT steering
Tx Rx sequencer
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
Summary of GPIO connections
The BCM numbers in this table correspond to the connector labelling on the Willow Electronics GPIO breakout board. Two of the connections are not broken out and need to be directly connected to the GPIO pins. More details to follow.
