Antennae changeover relays
Revision as of 18:59, 19 September 2017 by G8GTZ (talk | contribs) (→‎Coil voltages)
146 and 70cms
For 70 cm you can use reasonably cheap BNC relays like those above and the Cx540 which are often available surplus. SMA relays are much more common for about £10 and up at a rally or microwave round table. It helps to know what you are looking for, RLC, Radiall, Teledyne etc.
On the input I would tend to use something like the RS951 and you can pick them up at rallys for a couple of quid!
23cms and above
For microwaves 23cm and down you need microwave relays. These come in many types but the most common are TNC, N or SMA. Good N-type relays (not the CX520s) tend to be expensive.
Typical sma relays which are good up to 10GHz are shown below:
Coil voltages
Latching relays
Some relays require driving in to both positions - this can easily be achieved by using another DC changeover relay which is driven by the PTT line and switches the c/o relay DC supply to appropriate contacts.
Tx / Rx sequencing
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
Transfer or 4 port relays
