Antennae changeover relays
146 and 70cms
For 70 cm you can use reasonably cheap BNC relays and the Cx540 N type relay which are often available surplus.
SMA relays are much more common for about £10 and up at a rally or microwave round table. It helps to know what you are looking for, RLC, Radiall, Teledyne etc.
On the input I would tend to use something like the RS951 and you can pick them up at rallys for a couple of quid!
23cms and above
For microwaves 23cm and down you need microwave relays. These come in many types but the most common are TNC, N or SMA. Good N-type relays (not the CX520s) tend to be expensive.
Typical sma relays which are good up to 10GHz are shown below:
Coil voltages
Latching relays
Some relays require driving in to both positions - this can easily be achieved by using another DC changeover relay which is driven by the PTT line and switches the c/o relay DC supply to appropriate contacts.
Tx / Rx sequencing
To go to Tx:
1) Turn off receiver pre-amp
3) Apply power to PA
To go to rx
a) Turn off Tx
c) Apply power to pre-amp.
Transfer or 4 port relays
A lot of surplus microwave relays are transfer relays - these can easily be recognised by having 4 connectors or ports. These are entirely suitable for use as 3 port change over relays and can actually be used to provide additional protection to your pre-amp by putting it in to a 50 ohm load on transmit.
