5.6 GHz
Revision as of 22:01, 19 September 2017 by G8GTZ (talk | contribs) (→Rx)
Frequency choice
The FPV equipment receive and transmit frequencies are set using DIP switches, and most tune to this frequency but care needs to be taken when selecting equipment to make sure it does cover this frequency. Example channel tables are at the bottom of this page.
Equipment
Mounting the equipment
G8GKQ 6cm Transceiver - .
Transmit amplifiers
Antenna change over relays
Reverse SMA
24v relay operation
Antennas
Video equipment
Rx
The receiver output will need to be directly connected to a composite video input monitor to view the received the signal - normally on a yellow phono or RCA connector. Beware of using modern flat screen monitors which have a video squelch which will not display noisy signals and just give a blue screen until they get a strong video signal.
Video squelch defeat
There are a number of circuits around to defeat the squelch:
Tx
On the air
Activity hot spots
Know users include:
  • Ludlow, Shropshire = G8XYJ
  • Yorkshire = G8BYN
More information
Technical information
The rx chip in most units has got the number removed, however it appears the rxr is based on an SM201R module. The spec and pinout are shown below but beware the frequency range of this unit does not seem to cover 5665MHz, so make sure the one you buy does!
S meter output
It appears the unit using a 480MHz IF (same as the Comtech) and more interesting the RSSI is available on pin 17 and could potentially be used for a signal strength meter to help align the antennae.
Channel Listings
The channels settings vary from manufacturer to manufacturer. This table is taken from the Tarot data sheet:
And this is a table from another manufacturer:
