Minitiouner Hardware
Original schematics are here : http://www.vivadatv.org/viewtopic.php?f=80&t=366
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
The project had previously used several tuner types and a version 1 PCB and adapter cards - new builders should only use the Serit tuner and version 2 PCB.
- The USB interface is available ready programmed from the MiniTiouner category in the BATC shop.
- The version 2 main PCB can be bought from the BATC shop.
- The tuner or NIM. The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
- The unit uses an MCP1826 1v regulator, which can be hard to find and is available from the BATC shop.
All other components such as Rs and Cs are available from normal suppliers. A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts directly from Digikey.
MiniTiouner main PCB
There are 2 variants of the MiniTiouner main PCB which contains the power supply components for the 5, 3.3 and 1 volt rails. As of April 2017 new builders should only build version 2.
New builders should go to this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Feb 2017
USB module
Note - some people have noticed what appears to be a solder short between 2 pins on the IC on the USB module - see below - this is perfectly normal.
The NIM
The NIM or Network interface module is the little metal box found inside Satellite Receivers (also called the tuner) and typically contains 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
Note: You only require the adaptor PCB if you are upgrading existing MiniTiouner hardware to include the Serit tuner. Check this page to work out if you should upgrade.
Fitting a lock detector
