Revision as of 13:59, 21 September 2017 by G8GTZ (talk | contribs)
Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page and the Serit tuner described here.
Parts list and schematic
The parts list and schematic can be downloaded here:
Note the 22uF electrolytic capacitors on the regulators are High ESR types chosen to minimise oscillation - substitute at your peril! Ceramics can be used instead but through hole 22uF ceramics are expensive.
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
File:SERIF.pdf
File:Seritpartsv3.xls
Setting up the hardware
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
On the air
