5.6 GHz
Frequency choice
Equipment
Mounting the equipment
Transmit amplifiers
Antenna change over relays
Reverse SMA
Antennas
Video equipment
Rx
Video squelch defeat
- Syncsmurf by PE1RQM - kits are available details on the webpage here.
Results are very impressive:
- eachines FPV recorder
Several people have reported that they are using these devices, available from various sites, and as well as defeating the monitor blue screen by inserting syncs on noise they have a single push button record facility. They record to an SD card which can be removed and the files viewed on a PC.
- CQ-TV 129 included details of a Video sync processor:
- Or any video sync processor may be useable such as the Advanced Converter Enhancer used by many stations on 23cms FM.
Tx
On the air
Activity hot spots
Know users include:
- Ludlow, Shropshire = G8XYJ
- Yorkshire = G8BYN
More information
Technical information
SM201R
S meter output
Tx and Rx perfomance
Channel Listings
