5.6 GHz
Frequency choice
Equipment
Mounting the equipment
Transmit amplifiers
Antenna change over relays
Reverse SMA
Antennas
It is also possible to use a satellite mini dish with a suitable feed such as a wave guide horn to the design by G4NNS - see here for construction details: http://myweb.tiscali.co.uk/g4nns/FeedHorn.html
Video equipment
Rx
Video squelch defeat
- Syncsmurf by PE1RQM - kits are available details on the webpage here.
Results are very impressive:
- eachines FPV recorder
Several people have reported that they are using these devices, available from various sites, and as well as defeating the monitor blue screen by inserting syncs on noise they have a single push button record facility. They record to an SD card which can be removed and the files viewed on a PC but users report that you need to use a good SD card and have had problems with Kingston and Sandisk are preferred.
- CQ-TV 129 included details of a Video sync processor:
- Or any video sync processor may be useable such as the Advanced Converter Enhancer used by many stations on 23cms FM.
Tx
An old camcorder with a yellow phono video out socket is an ideal video and audio source for the transmitter but don't forget you will need to display your call sign to remain legal.
This can be a video generator, a jpeg card reader with video out, or a piece of card with your call sign scribbled on it!
Alternatively the BATC Portsdown project can be configured to deliver composite video and audio out from the Rpi multi-jack plug. This can be test patterns, Rpi desktop or the Portsdown camera and microphone - see this wiki page for more details.
On the air
FM voice only
Several stations in the Glouscester and Bolton area are using these units for wide band FM voice only - this is achieved by simply putting high level (1v p to p) audio on the yellow video tx phono and listening with a powered amp on the yellow Rx phono amp.
As it is using the same bandwidth rx and tx system, performance will be no better than FM video - ideally the 480MHz rx IF would be tapped off in to an SDR or narrow band receiver to give significantly enhanced (+20db?) narrow band performance.
Activity hot spots
Know users include:
- Ludlow, Shropshire = G8XYJ
- Yorkshire = G8BYN
More information
Technical information
SM201R
S meter output
Tx and Rx perfomance
Channel Listings
